Heavy springs?
  • dumb_dom
10 Nov 2017 22:25 #186066 by dumb_dom
Heavy springs? was created by dumb_dom
Hey guys quick question, I use my jimny a lot for work and have removed the rear seats and all so I can carry my logs and tools home after work, however it seems the springs to me seem pretty soft and the car sits pretty low at the back with only around 100kg worth of weight in, this might just be due to age but before I replace them with standard new coil springs I was curious if you can get stiffer standard length ones to withstand heavier loads or would I be better fitting a 2” lift giving me that extra 2” aswell and going for a stiff 2” kit
10 Nov 2017 23:01 #186068 by Busta
Replied by Busta on topic Heavy springs?
I had the same problem so fitted a pair of front springs (purchased off someone who had just lifted their Jimny) on the rear. It gives a small lift (30-40mm) and handles heavy loads a lot better. I had to chop 3/4 of a coil off the nearside spring to correct the Jimny lean but otherwise they fit straight in and the ride and handling remains the same.
11 Nov 2017 06:10 #186073 by Lambert
Replied by Lambert on topic Heavy springs?
There are no springs specific to the Jimny that gives you what you are looking for,standard height and stronger rate. There is another car that has springs that will physically fit but they are way too tall for a standard height replacement and are massively hard. They would require to have multiple coils cut off making them even harder. I keep looking at them to try and reconcile the massive loss of articulation against the ability to carry loads and have yet to convince myself that they are for me. Quite honestly Busta has probably the simplest and most effective way to proceed especially if the load in the back is fairly constant and you are just needing to relevel the car.
  • dumb_dom
11 Nov 2017 20:08 #186087 by dumb_dom
Replied by dumb_dom on topic Heavy springs?
Thanks guys, might try the front springs on the rear, makes good sense.
  • Barry
12 Nov 2017 14:10 #186119 by Barry
Replied by Barry on topic Heavy springs?
That's a coincidence, I'm just about to buy a Jimny and remove the rear seats, too, for my work. I was going to go for a 2" lift anyway - with 215/75r15s. So should I go for 2" at the front, but 3" at the rear? Though I don't want to go replacing brake pipes and suspension bits. I will only be carrying tools, but they aren't light ones. I currently drive a small Fiat van, and when I take the tools out, it behaves differently (better). Thanks.
  • TomDK
12 Nov 2017 14:53 #186121 by TomDK
Replied by TomDK on topic Heavy springs?
If you want 2" lift specifically for driving with heavy load, the the Trail Master 3" springs are no question the best option. They're actually only 2" longer than standard springs, but made of 13mm wire and of very good quality.
Time to create page: 0.115 seconds
