Help needed Identifying the correct cv joint?
  • NineCherries
08 Nov 2017 09:05 #185996 by NineCherries
Help needed Identifying the correct cv joint? was created by NineCherries
Not been on the forum for ages as real life took over again ;) but I’m hoping to dip into the knowledge on here to help me again.
I’m running out the door heading to work so don’t hate me if there is a similar post that I missed over breakfast :)
Q. Can you identify spline/ ball combo of the CV fitted to the car from the year (57 plate 2008) or engine identification (16v m series)? Or do i need to remove the driveshaft? I need the car for daily transport so don’t really want to put it off the road to find out what cv I need. The plan is to order the parts and have them sitting for my week off at the end of the month and do the repair then.
Any help/ advice on suppliers would be much appreciated.
That is again in advance for any help given.
Tony
08 Nov 2017 11:45 #186008 by mlines
Whats the registration number (PM me if you do not want to put it here)
  • NineCherries
08 Nov 2017 15:20 #186017 by NineCherries
Replied by NineCherries on topic Re:Help needed Identifying the correct cv joint?
It’s cool. J 70NY T
Thanks Martin.
08 Nov 2017 15:54 #186018 by mlines
My system shows it as being a
8 balls, 26 external splines and 29 internal splines CV - Suzuki part 44102-84A00
This one in the store
www.bigjimny.com/store/cv-joint-type-2.html
I have a "pre-opened" one of these (sent to a customer, tried it but it didnt fit his car, covered in oily fingerprints but never used) for £50 if you do not mind the opened box.
  • NineCherries
08 Nov 2017 16:39 #186020 by NineCherries
mlines wrote: My system shows it as being a
Sounds good. I’ll pm you later this evening when I’m home from work. Much appreciated.
  • NineCherries
28 Nov 2017 14:57 #186815 by NineCherries
Successfully installed the CV Joint today. Pity the kingpin bearings need replaced too. Martin if you read this check your messages :) please. Tony.
Time to create page: 0.104 seconds
