Immobiliser question
- Davegtiuk
03 Nov 2017 21:04 #185819
by Davegtiuk
Immobiliser question was created by Davegtiuk
Hi folks,
We have a 2004 1.3 manual Jimny
It has an intermittent starting problem.
It turns over fine ( new battery), often starts fine, but sometimes won't fire at all.
Our local garage has plugged in their diagnostic machine in and every time it won't start it shows an immobiliser fault.We have had a new key cut and programmed and it hasn't solved the problem.
We are considering buying a s/h immobiliser unit and matching key on eBay - the plan being that we would unplug the four wire connector from our immobiliser, plug into the spare, locate the spare key inside the spare immobilisers sensor ring, and use our key to start the vehicle. This should tell us whether the problem is that our immobiliser unit is faulty ( and if it is, we'd fit the spare and have our keys reprogrammed.
However from trawling through other threads, I wonder if the spare immobiliser will work with our ecu. I'd have thought the immobiliser would simply send a signal or no signal to the ecu. However maybe they have to be matched somehow.
Thanks in advance
David
Thanks in advance
David
04 Nov 2017 20:04 #185843
by Rhinoman
Replied by Rhinoman on topic Immobiliser question
The immobiliser has to be matched with the ECU. The problem could be as simple as dodgy wiring to the back up supply on the ECU.
- Davegtiuk
22 Nov 2017 14:52 #186599
by Davegtiuk
Replied by Davegtiuk on topic Immobiliser question
Thanks Rhinoman.
It could be a ECU wiring issue -possibly an earthing problem.
We have applying wd40 to all of the earthing points we can find, and the problem appears to have gone.
Rgds
David
Rgds
David
Time to create page: 0.070 seconds
