Shifter Sheet?
  • leeds83
01 Nov 2017 10:32 #185707 by leeds83
Shifter Sheet? was created by leeds83
Following on from another post I've got on here, my shifter is very very loose having now put it back together and won't go into 1st. I might have lost this out when removing or it was already perished.
Having done some research on here, seems the problem might be the plastic bush from the bottom of the transfer box.
Does anyone know where I can get one? Really struggling to find a replacement!
It's the very last stage of fixing my Jimny up.
01 Nov 2017 11:02 #185709 by mlines
Replied by mlines on topic Shifter Sheet?
Which box are you referring to? Transfer box or Gearbox. you talk about "1st Gear" but also talk about Transfer box
The "shifter sheet" and related issues are really focussed on the SJ series of vehicles.
There are components in the jimny remote set up which are similar. Need a bit more detail to be honest
  • leeds83
01 Nov 2017 11:45 #185711 by leeds83
Replied by leeds83 on topic Shifter Sheet?
Sorry, i'm referring to the gear box.
Basically the gear shifter is wobbling all over the place after putting it back in. A few articles I read seemed to refer to this lower bush.
2003 jimny
  • leeds83
02 Nov 2017 09:01 #185741 by leeds83
I think it's number 20 on the diagram below.
  • leeds83
02 Nov 2017 09:45 #185743 by leeds83
OK
Problem solved, found the part number 2555160A02 see below
This is the missing bush that must have dropped out at some point, Suzuki in Leeds have one in stock £4.99.
Time to create page: 0.090 seconds
