Help please, exhaust towbar clearance issues.
22 Oct 2017 13:44 #185418 by weecorey
I've just fitted a bosal towbar and replaced the mid pipe and back box, the back box is touching the towbar on the lower passenger side corner, the back box isn't sitting level. Should the back box sit level with the ground? There is a u section channel which runs at an angle above the rear panhard rod, it has 2 x 8mm threaded holes in it, should there be another exhaust mount support bolted on here or what are these fixings for? I've an mot on Tuesday and need to get this sorted asap. Thanks in advance.
22 Oct 2017 13:45 #185419 by weecorey
22 Oct 2017 14:44 #185421 by jackonlyjack
  • mickt
22 Oct 2017 18:18 #185428 by mickt
If its not an original replacement then the copiers can sometimes get the angles wrong!
22 Oct 2017 18:48 #185430 by weecorey
Thinking that myself, I've took the mid pipe off and I'm going to adjust the bend a bit tomorrow at work.
23 Oct 2017 05:19 #185437 by yakuza
After having alot of problems with Bosal, Walker and other aftermarket exhaust parts that broke and cracked due to bad fitment I only buy original exhaust parts both for my VW and my Suzuki. Problems with bad parts was on a Suzuki SJ and a Opel/vauxhall but i was fed up after returning the broken parts to the shop three times.
And the original parts is not htat more expensive if you take the problems into the maths.
I bought and fitted a thule towbar that was more flush under the car than the others. I have seen some towbars that hang out beneath the car like an anchor.
After this i have to take the back box out the opening in your picture.
Time to create page: 0.098 seconds
