Steering damper mount touching steering arm
- Iaitoo
18 Oct 2017 14:44 - 18 Oct 2017 14:51 #185356
by Iaitoo
Steering damper mount touching steering arm was created by Iaitoo
Hey! Got my steering damper in the mail today. Tried to mount it as the guide says. But the mount ends up 1mm from the arm, and no room for the damper. From most of the pictures Ive seen, the damper is above the steering arm, not in line. Mine is LHD, but that sould not matter? Could it be that my springs have sagged so much that it is touching? The steering arm is almost vertical..
Last edit: 18 Oct 2017 14:51 by Iaitoo.
18 Oct 2017 16:54 #185358
by Keithy
Replied by Keithy on topic Steering damper mount touching steering arm
I'm not sure what I'm seeing in the picture.....are you fitting it to the side opposite the steering box?
- Iaitoo
18 Oct 2017 17:33 #185359
by Iaitoo
Just showing how close it is to the steering bar/rod.
Yes, opposite side
On the metal pipe hole thingy on the frame. Would be easier if I could flip the mount, but won't be able to use the other plate that it screws in with cause of some mount thingy on the frame.
Replied by Iaitoo on topic Steering damper mount touching steering arm
Keithy wrote: I'm not sure what I'm seeing in the picture.....are you fitting it to the side opposite the steering box?
Yes, opposite side
18 Oct 2017 21:12 #185362
by Keithy
Ahh I see...Could you move the doodad to the other side of the wotsit?
- Thank you received: 2004
18 Oct 2017 21:34 #185363
Replied by Lambert on topic Steering damper mount touching steering arm
I'm having trouble visualising the bars mirrored for the lhd but certainly on my rhd there's no way of getting that bracket anywhere near the bars. It just rests up against the back of the round cross member on the inside of the chassis rail well away from anything?
- Thank you received: 227
19 Oct 2017 00:30 #185364
by zukebob
Replied by zukebob on topic Steering damper mount touching steering arm
I also have a LHD Jimny and I had the same problem with my steering damper. The one I purchased is the toughdog. It is made in Australia for the RHD Jimny. I am not sure if this is a consistent issue or not with dampers designed for RHD being used on LHD vehicles. I no longer have a picture to show (thanks photobucket) but I took mine to a machine shop and had a weld on bracket fabricated that would move the one end of the damper forward. That eliminated any interference with the linkage.
