Jimny hot running issues...
12 Oct 2017 19:25 #185145
by mark98
Jimny hot running issues... was created by mark98
Long time no post...I do still have my Jimny, but in more recent months it plagued by consistent but irritating hot running. Only runs hot at speed (over 65-75, any less and its totally fine), when off road at slow speed and when idling for extended periods. It can be controlled and will run all day fine if the heater is turned up to the max and blasting at full speed. I have tried to remedy this several times. It has had in the past 12 months a new head gasket, new rad, new thermostat and just last week a new water pump. I'm starting tow wonder if its really worth continuing to pour money into this problem. I am seriously considering selling it if I can't sort this hot running our once and for all. I do not really want to do this, as I have spent lots of time and money on my Jimny over the past 2 years, but I am getting sick of pouring in money to not get results. I've been told that the viscous fan could be not working effectively, is there anything else worth checking/changing before I take the route of selling it? Any advice really is appreciated...
12 Oct 2017 19:44 #185147
by Keithy
Replied by Keithy on topic Jimny hot running issues...
Travelling at speed the viscous fan wouldn't be engaged....unless you have too little airflow through the radiator.
If turning the heater on makes the overheating manageable then you have a lack of liquid flow through the radiator, lack of airflow....headgasket failure or a cracked head......or a lying temperature gauge/sender.....test for each and you're done....you get 45 minutes to check it all out....or you're sacked!
12 Oct 2017 19:47 #185148
by mark98
Replied by mark98 on topic Jimny hot running issues...
Cheers...hows best to check the temp gauge isn't lying to me? If its been that all along then there will be a very Basil Fawlty style moment...
13 Oct 2017 10:11 #185163
by Keithy
Thermometer....I have a contact one.....must get myself a non contact one. also check the thermostat.......the heater circuit works independent of the thermostat.
13 Oct 2017 10:48 #185168
Replied by mlines on topic Jimny hot running issues...
To check the viscous fan, get the vehicle up to the point where you consider it "hot" and then stick a rolled up newspaper into the fan blades. If it shreds the newspaper, your fingers and your arm then it is fine. If the newspaper stalls the fan then it is stuffed.
The following user(s) said Thank You: mark98
13 Oct 2017 16:35 #185179
by Keithy
And remember....halfway up the forearm counts as zero!
Time to create page: 0.101 seconds
