Jimny -2003 3" lift and 195/80/15
- 1066Boy
13 Oct 2017 14:54 #185176
by 1066Boy
Just the shock on landing. The mount may have already cracked, I don't know.
Jumping any vehicle is not really a good idea. Time in the air is time lost (no power transmitted to the ground) and unpredictable landing etc.
Replied by 1066Boy on topic Jimny -2003 3" lift and 195/80/15
Millen wrote: 1066Boy:
Did something hit the transferbox or did it just break because of the shock?
13 Oct 2017 18:22 #185186
by Busta
I use 215/75s on a standard Jimny with no lift and the anti roll bar removed, and it takes me anywhere I want/need to go- green laning, pay and plays, use around the farm etc. The only 'limitation' compared to a lot of the heavily modified Jimnys is ground clearance, but to gain any more I need to make a lot of changes- lift, gearing, camber correction, extended hoses etc. I don't want that sort of expense and compromise on my daily driver. For a close to standard car you can't really fault it.
If you are unsure what you need to do to your Jimny I'd definitely suggest fitting either 195/80 or 215/75r15s and just driving it. You'll soon get an idea what works for you and what needs changing. I see so many people fitting big lifts and 31s before they have even driven their Jimny off road. Then they break CVs, burn out clutches, snap off shock mounts etc. and end up spending a small fortune on all the little details you need to make a Jimny with big wheels work.
Replied by Busta on topic Jimny -2003 3" lift and 195/80/15
Millen wrote: Anyone more here that uses relatively thinner tires to tackle obstacles or someone who have opinions of the plus and minuses of not going wide?
- Millen
13 Oct 2017 19:43 - 13 Oct 2017 20:19 #185190
by Millen
Replied by Millen on topic Jimny -2003 3" lift and 195/80/15
Busta:
Yeah, I already had sort of a bad clutch to start with so I did that thing, now I drive it carefully instead of going up steep rocky and muddy terrain.
This until I decide what clutch to get, that's another jungle.
I have quite fresh friction tires on now and those has done a very good job on asphalt and loose stuff.
Guess they wear fast thou but have done some light drifting with them to get a feel for the car and it's a nice ride.
Just before I was thinking, maybe I should "just" do the clutch, get rear and front ARB diffs controllable from inside.
Or just some others diffs with same functions.
Maybe it can do really nice with that and the studded winter tyres going up mountainpasses in Norway this winter.
Or, I almost know it would, it's a Jimny, there is a reason I saw them all over in the Alps in august.
From what I've read the 80s would not fit without some heightening.
I would concider tyres even higher, there might be some good ones. Maybe I go wider later.
Changes in the transferbox is tempting to.
I'm thinking 3", in case I might want to try bigger tyres to, and get more travel.
More lift and the center of gravity would change thou, but we will see what will happen.
1066Boy:
Sounds gnarly :S
But you could jump over obstacles to.
1066Boy:
Sounds gnarly :S
Last edit: 13 Oct 2017 20:19 by Millen.
13 Oct 2017 21:19 #185195
by Busta
195/80 will definitely fit without a lift or trimming. A standard height Jimny on good tyres with arb lockers would be extremely capable!
- Millen
13 Oct 2017 23:06 - 14 Oct 2017 13:04 #185198
by Millen
Busta
I think I get a set plus spare then.
www.jimnybits.com/wheels-and-tyres/tyres...x4-offroad-tyre.html
They look quite fast, duno.
Would they fit with chains thou?
About the open/lockable diffs, should I concider limited slip to?
With the diffs open/LSD, do I have to worry about 4x4 on grippy surface at all? What is the actual problem with driving with them on that while locked? To much stress on one of the front wheel sides while turning sharply?
Last edit: 14 Oct 2017 13:04 by Millen.
14 Oct 2017 20:23 - 14 Oct 2017 20:31 #185236
by Busta
I'm not sure about chains. I guess they would be fine on level roads but might catch if the system flexed a lot.
I don't know of any LSDs available for the Jimny.
The problem with 4x4 on grippy surfaces is that there is no centre differential. When you turn, the front wheels have to travel further than the back wheels and without a centre differential this can not happen. It puts a load on the transmission called 'wind up' and causes accelerated wear and breakages! Regardless of what diffs you fit you can't use a Jimny on grippy surfaces in 4wd.
Last edit: 14 Oct 2017 20:31 by Busta.
The following user(s) said Thank You: Millen
Time to create page: 0.858 seconds
