Jimny -2003 3" lift and 195/80/15
- Thank you received: 1927
10 Oct 2017 07:55 #185039
Replied by Lambert on topic Jimny -2003 3" lift and 195/80/15
As Busta says the axle and diff are one solid unit with wheels at each end. There's 2 ways of getting more clearance, one fit much taller tyres, two fit portal reduction hubs and taller tyres.
The following user(s) said Thank You: Millen
- OllieNZ
10 Oct 2017 08:18 #185040
by OllieNZ
Replied by OllieNZ on topic Re:Jimny -2003 3" lift and 195/80/15
You can also "shave" the bottom of the diff casing which can gain any where from 1/2-1 inch
I suggest spending some time googling "live axle suspension" "solid axle suspension" "radius arm suspension" to try and get your head around how the jimny suspension works as it's very different to most other modern cars and 4x4s
10 Oct 2017 08:26 #185042
Replied by Lambert on topic Re:Jimny -2003 3" lift and 195/80/15
Just because you can, would you really want to shave the bottom of the diff case?
- OllieNZ
10 Oct 2017 13:01 #185049
by OllieNZ
Compared to some of the other major mods available it's a pretty simple and cheap one. It also allows you to increase the thickness of the bottom of the diff casing without losing the ground clearance caused by a bolt on diff guard. Depending on how you shape it, it can also help reduce hang ups.
If you use cv/double cardan type drive shafts you can angle up the diff input to point directly at the t-case increasing the amount of case you can cut away.
However doing this will mean moving spring/shock attachment points back on top of the axle and having to cut and reweld the swivel balls on the front to correct caster.
Replied by OllieNZ on topic Re:RE: Re:Jimny -2003 3" lift and 195/80/15
Just to clarify by diff case I'm referring to the portion of the axle case under the diff ring gear.11/60 wrote: Just because you can, would you really want to shave the bottom of the diff case?
- Mraz
10 Oct 2017 14:00 #185051
by Mraz
Replied by Mraz on topic Jimny -2003 3" lift and 195/80/15
Well... you could put portals on it and get a lot higher diffs without the need for large (heavy) tyres and regearing but it's not cheap.
- 1066Boy
10 Oct 2017 15:57 #185057
by 1066Boy
Replied by 1066Boy on topic Jimny -2003 3" lift and 195/80/15
Much the same off road, just having a bit more diff clearance with the 215/75.
Time to create page: 0.200 seconds
