Body shift
Topic Author
- Thank you received: 706
07 Oct 2017 17:33 #184953
Body shift was created by jackonlyjack
After recent suspension lift 2.5"
body shell as shifted to the right
could this be because i have 3" castor correction arms x4 so slightly over castored
also can anyone tell me or take a picture of their pitman arm with wheels straight
so i can see what angle it's supposed to be at
thanks
Jack
thanks
Jack
- Thank you received: 2004
07 Oct 2017 17:51 #184954
Replied by Lambert on topic Body shift
Do you have adjustable panhard rods to recenter the body?
Topic Author
07 Oct 2017 18:02 #184955
Replied by jackonlyjack on topic Body shift
Yes but the issue i have
is that the body should move to the left (i've been told) after a lift
so the adjustable panhards will only push it more to the right
- Wokka
07 Oct 2017 18:48 #184958
by Wokka
Replied by Wokka on topic Body shift
Silly question.
Are you looking from the front or back?
07 Oct 2017 19:01 #184959
by Busta
Replied by Busta on topic Body shift
Panhard rods control left/right positioning. It won't be the castor arms. Sounds like your adjustable panhard rods are too long!
Topic Author
07 Oct 2017 19:33 #184961
body moved over to our off side/driver side Wokka
Busta that's what i was thinking.....could be a problem as standard ones went for scrap :pinch:
only need 4mm travel to get them central
so grinder out to remove a bit of length me thinks
steering wheels out too but i need to sort body position out before tracking
or steering my have moved when i did body lift and removed the shaft
thats why i asked about pitman arm angle
Jack
Jack
Time to create page: 0.095 seconds
