Sand rat
  • Wokka
02 Oct 2017 04:16 #184722 by Wokka
Sand rat was created by Wokka
Location wise, 98.3% of my off road driving will consist of sand. Previous cars I've had out here haven't been short of power, so I ran either aggressive AT's or MT's
Red rocket/radio flyer (still can't decide on a name yet) will be set up as more of a mini overland truck, something that allows me to get out into the desert over the weekend where I can chill out by a fire with a nice bottle of scotch, my dog, and whatever can I decide to bring for food.
Current direction:
2" suspension lift- done
Steering stabilizer - done
2"body lift - not yet, but ordering this week
Spacers/large offset rims - done 15x7 +45mm total
High clearance front bumper - done
Awning - done
Drawer - will knock up this weekend
Under roof high storage - will play with it this weekend
Dog barrier - will bolt between the drawer and roof box
275/70 r15 ish tires - once drive train mods are done the wider and softer, the better
Kaiser front and rear lockers - ordering this week
Now the tricky part,
# Do I keep the 27k m13aa motor currently in there and go for the jimnybits hi/low reduction box, or do I keep a lookout for an m15a/m16a and keep stock gearing
# Load index requirements on the tires are pretty low compared to most 4x4s. I realise that load index and a soft sidewall don't necessarily always go hand in hand, but for maximum flotation on sand I need the soft sidewall. Has anyone come across a lovely soft sidewalled tyre? Preferably in HT or even passenger car tread. AT's tend to be a little too diggy for low powered cars on the soft stuff
# desert runs so far have shown she is happiest in low range, gears 2, 3, and 4
# finally, speed limits out here top out at 140km/h, while I don't need to hit that speed, I'd prefer not to be a speed bump in traffic, she currently is comfortable at 110, I'd like to keep that capability at least
Shiny side up
02 Oct 2017 04:27 #184723 by Lambert
Replied by Lambert on topic Sand rat
I don't have much sand to drive in but i do have mud. I would however be more inclined to put the bigger motor in it that way you can maintain speed and torque simultaneously. With the 1.3 and lower gearing while it will maintain the torque at the wheels it will be at the expense of speed. Probably, I have very little direct experience of desert driving.
02 Oct 2017 05:57 #184725 by kirkynut
Replied by kirkynut on topic Sand rat
I would go for the bigger engine first ans then decide if lower ratios are required too. Engine breaking still won't be great.
I'd think about a 1" body lift instead of a 2" one as less needs changing but I know an inch makes all the difference to us blokes!
The Kaiser diff in the front might be a pain! Not on sand but on any other surface that's not quite as loose that you want 4x4 for. The cv's are weak don't forget, what with that bigger engine too.
Perhaps put the money from the from Kaiser towards hardened cv's and front shafts and then if you think you need a locker in the front in the future you could save for an arb.
02 Oct 2017 18:39 #184751 by Riccy
Replied by Riccy on topic Sand rat
Engine every time! i have a swift 1.6 vvt and it worked very well with the standard 2007 drivetrain using 235/75r15 tyres (29.3" diameter).
Now its all different for green lanes, but will still sit happily enough at 60mph (just under 100kph). it will do 80 but is screaming on the revs and drinks fuel.
The bigger engine makes it much more useable, as said above. if taking it easy its no worse on fuel than many standard jimnys. Aerodynamics are bad so things like a roof rack/tent really drag it down.
  • Wokka
02 Oct 2017 21:49 #184764 by Wokka
Replied by Wokka on topic Sand rat
I"ve driven lock rites, and air lockers in the front on sand, and they both suck when engaged, reading up on the tech and speaking to people running Kaisers in the front, I'm comfortable rolling the dice as they allow over run but won't let any wheel spin slower than the ring.
I've gone with the rear only for now, along with the 2" lift to give me a range of tyres up to 30" ish.
Speaking to a couple of local tuner guys, on the slow hunt for a swift sport half cut for the doner engine, but the beating my bank balance has taken in the last week means it might be a slow search
At 30p a litre, I'm not really fussed about fuel economy.
04 Oct 2017 09:09 #184819 by Busta
Replied by Busta on topic Sand rat
Lock rites and kaisers operate in the same manner, although use slightly different mechanisms to achieve it. If you've had problems with one don't expect the other to be any better.
Time to create page: 0.114 seconds
