King pin replacement question.
30 Sep 2017 14:10 #184676 by weecorey
I'm in the process of replacing the kingpin bearings, I've watched the video but I've a question, when half shaft is removed oil runs out, I'd imagine from the front diff, this is normal right? It's just that no oil comes from the axle casing once the half shaft is removed in the video. Just a matter of letting it run and then refill the diff once finished?
30 Sep 2017 14:15 #184677 by weecorey
On 2nd thoughts this probably isn't normal, anyone know what the issue is?
30 Sep 2017 14:30 #184678 by Lambert
It depends on the angle of the axle if the oil will drain out of the open side. I had oil everywhere first time i did it and had to refill the diff once back together. Now i make sure that the open end is sufficiently higher than the other to keep the job a little cleaner.
30 Sep 2017 15:27 #184681 by weecorey
Yeah, I spoke to my mate who's a mechanic and he said it would be normal.
  • mickt
30 Sep 2017 17:52 #184682 by mickt
Replied by mickt on topic King pin replacement question.
Just ensure that when finished and the car is back on the level ground that the oil diff level is checked. That is opening the fill plug and oil should be up to the lip.
01 Oct 2017 20:32 - 02 Oct 2017 05:37 #184716 by kirkynut
Yeah, just jack up the side you're working on to make the oil run down to the other side.
Last edit: 02 Oct 2017 05:37 by kirkynut.
