Radius arm removal
28 Sep 2017 20:40 #184623
by weecorey
Radius arm removal was created by weecorey
I've the car up on axle stands positioned just behind the wheels on the axle casing, I want to remove the radius arms for painting, can I remove one front and one rear without anything moving?
28 Sep 2017 21:55 #184624
by Busta
Replied by Busta on topic Radius arm removal
I'd want the axle stands under the chassis. You can do what you want with the axles then.
- OllieNZ
29 Sep 2017 07:27 #184632
by OllieNZ
Replied by OllieNZ on topic Re:RE: Radius arm removal
I'm with Busta on this one. You need to support the chassis or the axle will flop off the stands under the pressure of the springs.Busta wrote: I'd want the axle stands under the chassis. You can do what you want with the axles then.
- Thank you received: 2004
29 Sep 2017 07:45 #184633
Replied by Lambert on topic Re:RE: Radius arm removal
When I replaced the front axle on mine i had the chassis on one set of stands and the axle on another at full droop. Wasn't much fun fighting it back into the right position. Just for painting I would be leaving them in situ and not worrying overly about the bits I couldn't see.
29 Sep 2017 07:48 #184634
Oh and leaving the springs in without the swing arms is ask to get maimed
29 Sep 2017 19:59 #184663
by weecorey
Replied by weecorey on topic Re:RE: Radius arm removal
I think I'll paint them where they are.
Time to create page: 0.103 seconds
