Muffed knocking from front suspension
- pkuna
14 Sep 2017 06:28 #184100
by pkuna
Muffed knocking from front suspension was created by pkuna
Hello!
When I ride on unevenness I hear some muffed knocking from front suspension.
I replaced the stabilizer's joints, but that did not help.
What could be broken?
Thank you.
Regards
Thank you.
Regards
- Thank you received: 2004
14 Sep 2017 07:02 #184101
Replied by Lambert on topic Muffed knocking from front suspension
Check that all the bolts that attach to the axles are correctly torqued, so panhard, swing arms and dampers on both ends. This will also let you check for other damage and excessive wear in brackets etc.
14 Sep 2017 09:41 #184106
Replied by Daniel30 on topic Muffed knocking from front suspension
Check your exhaust, sound plays funny games with you underneath the Jimny
- jim
14 Sep 2017 20:08 #184139
by jim
Replied by jim on topic Muffed knocking from front suspension
As Daniel30 says check the exhaust, there are a few heat shields that can rattle around.
- jim
15 Sep 2017 13:00 - 15 Sep 2017 13:01 #184154
by jim
I had a bit of a slight knocking sound from my driver side front wheel and it was a worn anti roll bar drop link. I only fitted a new pair around December time.
Last edit: 15 Sep 2017 13:01 by jim.
- 1066Boy
16 Sep 2017 09:24 #184173
by 1066Boy
Replied by 1066Boy on topic Muffed knocking from front suspension
Mine was doing the same. It was the bolts loose on the radius arms/front axle joint.
