4wd locked
  • sonny85cl
04 Sep 2017 14:32 #183871 by sonny85cl
4wd locked was created by sonny85cl
Hello friends, I have read many answers from this forum but I have not come to the solution, I have a 2008 Jimny with buttons, and when activated 4wd connect the front wheels and flash the traction light on the panel, therefore I can not go back to 2wd or even advance to 4wd-L, the only way to return to 4x2 is to open the actuator and turn the handwheel. Disculpen my English this translated by (Google Translate)
Can you help me please? I have not solved the problem for a month.
thank you very much
04 Sep 2017 20:08 #183878 by auchenblae
Replied by auchenblae on topic 4wd locked
Sorry but if you read my write up it advises you what to do.
www.bigjimny.com/index.php/forum?view=to...id=7&id=61277#174909
If the english is the problem and it is very complicated , I'm afraid you need to take the car to a Suzuki dealer as most garages will not be able to fix it.
eddie
24 Swift Ultra ALLGRIP
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
  • sonny85cl
04 Sep 2017 20:36 #183881 by sonny85cl
Replied by sonny85cl on topic 4wd locked
So you tell me there is no solution? or follow the step of the psot that you indicate me :(
  • Mraz
05 Sep 2017 08:25 #183882 by Mraz
Replied by Mraz on topic 4wd locked
There IS a solution that will probably work.
You need to override the vacuum sensor in engine bay and fool the system to think everything is OK with vacuum.
It's a simple fix and works when replacing vacuum hubs with manual ones, easyer than blocking vacuum pipes and hoping it works
  • sonny85cl
05 Sep 2017 14:06 #183887 by sonny85cl
Thanks @Mraz for the answer, where do I find the vacuum sensor? to be able to cancel and test.
what should happen?
Thank you very much
  • Mraz
05 Sep 2017 20:19 #183897 by Mraz
Vacuum sensor is under your fuse box, it's a round thigy with two vacuum lines and a jack with two wires. Remove the jack and bridge it. It will fool the system into thinking vacuum is working and flashing light should stop. It will not help you with vacuum itself but you can keep the hubs engaged and still choose 2WD, 4WD and 4WD-L and drive normally. Your front differential will spin all the time, hubs are engaged so they connect the wheels with axles and differential but differential is not connected to transfer box when in 2WD so no problem there - assuming your problem really is vacuum.
This is how I bridged mine when I fitted manual hubs.
postimg.org/image/pppgj0gmd/
postimg.org/image/nnoz4rin9/
And this is the actual sensor: (pic from internet, mine is in the thrash)
postimg.org/image/bbm2r9usl/
Time to create page: 0.096 seconds
