strange noise.
- 1066Boy
21 Aug 2017 16:59 #183525
by 1066Boy
strange noise. was created by 1066Boy
Here is one for you clever people. Strange noise from driver side front wheel. Its not a knock or heavy thump more of a loud creak. :blink:
did it first a few months ago during some wet weather but with the long dry spell we have had for the last few weeks its been silent.
Washed the car today and it rained. Its back louder than ever. If I drive slowly in 1st gear up the rough track at work it dose it as the front axle flexes. I can make it do it by driving forward and then braking, just one click. then reverse and brake, just one click again. Only dose it on the road if I corner (right hand) so unload the weight on that wheel and then it dose it when it loads up again. If you have heard a landrover dislocate a rear spring off road you will know the sort of sound I mean. I have checked everything I can think off but cant find any movement any ware. Ideas please. :blush:
- Thank you received: 706
21 Aug 2017 17:46 #183526
Replied by jackonlyjack on topic strange noise.
have you checked where the spring sits on the axle
could be some sort of burr that the spring is jumping over
just a thought
Jack
just a thought
Jack
The following user(s) said Thank You: 1066Boy
- 1066Boy
21 Aug 2017 21:21 #183532
by 1066Boy
Replied by 1066Boy on topic strange noise.
thats sort of my thinking jack. I can feel it through the floor when it happens. The thing that is throwing me is it only seams to happen in damp/wet conditions
- Thank you received: 2004
22 Aug 2017 05:03 #183535
Replied by Lambert on topic strange noise.
Is the panhard rod bolted up good and tight? Mine was ratchet tight and made all kinds of odd noise once barred tight to the specified ft it has been silent?
- mike83
22 Aug 2017 17:33 #183551
by mike83
Replied by mike83 on topic strange noise.
I've just got rid of a creake from front drivers side mate.
I changed bearings, all rubber bits and it still did it.
I took springs out and put half dozen 1" bits of hose pipe round top coil, tight fit needed grease and channel grips to get them on. This made the coil sit a bit tighter at the top.
Went for a spin and the noise has gone.
- 1066Boy
22 Aug 2017 19:29 #183556
by 1066Boy
Thanks for that, will give it a go if I cant find any other problems.
Time to create page: 0.095 seconds
