Main beam spot lights
  • Russ6334
08 Aug 2017 12:33 #183242 by Russ6334
Main beam spot lights was created by Russ6334
Hello
I'm new to the forum after buying a W plate jimny for some off road fun in the south Devon area.
I've bought a led strip light and wired it up but I'm having loads of trouble, I've also found old threads where people have had the same and rectified it with advice but I can't make head nor tails out of the advice.
Basically using the relay I have:
30 fused to battery
87 to led +
85 to - batt
86 from main beam
Now when I turn my lights on the led works on main beam, when I turn the lights off the led comes back on.
Because it's permanent live, now if I put it to dipped beam when I turn my lights off the led is off! But with lights on I blind people but on main beam again off.
I've played around with the headlamp main dipped and earth (though it's not earth as no continuity to earth) and nothing will turn the spot light off with what lights unless I have it on dipped which is no good.
Neither do I want to fit a switch because again you either forget or you blind people and you have either dead batt or an RTA!
Help!
Where do i put 86??????
Don't take this as an offence but please don't direct me to other threads because equally I can't make sense of them!
Thanks
Russ
08 Aug 2017 15:22 - 08 Aug 2017 15:23 #183244 by mlines
Replied by mlines on topic Main beam spot lights
So with a permanent live set-up the main beam switch provides the GROUND (Battery minus)
So you need
1. 30 Fused to battery
2. 87 to LED Bar +
3. 85 to Battery Postive via fuse (just connect it to 30)
4. 86 to main beam wire.
5. LED bar - to GROUND
Last edit: 08 Aug 2017 15:23 by mlines.
  • Russ6334
08 Aug 2017 17:44 #183245 by Russ6334
Replied by Russ6334 on topic Main beam spot lights
Martin thanks!
Worked on dip beam now but if I swap the headlamp feed it works on main so ideal!
Cheers
  • 1066Boy
08 Aug 2017 18:34 #183249 by 1066Boy
Replied by 1066Boy on topic Main beam spot lights
I have one on mine and its great. The only downside is when you get used to the amount of light it makes
your dipped beam look crap. :)
  • Russ6334
09 Aug 2017 20:42 #183297 by Russ6334
Hi Martin
Well it worked for a day but for some reason when I turn the lights off now the spot light is on but low power. Also with the lights on it is also on with main and dipped but not sure how as when the light is off it has no power?
Not sure if it's relevant but I fitted LED headlamp bulbs today (and to be honest they beat the spotlights in any case) but since doing so this problem has arrived, also worth noting the "waterproof" spotlight was "Ford" tested yesterday and now has condensation!
Any ideas?
10 Aug 2017 04:25 #183306 by Lambert
Replied by Lambert on topic Main beam spot lights
As far as I am aware there is no approval for led replacement luminares in a reflector originally designed for incandescent ones. As in for led headlights the whole lamp assembly has to have been designed as an led unit to be legal. Unless it has changed in the last 6 months.
Time to create page: 0.126 seconds
