Combination switch help needed
  • jwb
06 Aug 2017 05:37 #183214 by jwb
Combination switch help needed was created by jwb
2000 Jimny has a problem with the indicators.
Indicators work fine in both directions as does hazard function.
When the indicator lever is in the off position the relay buzzes continually and when moving the lever slightly theres a burning smell from the switch! I suspect a short in the switch somewhere - anyone got any ideas other than replacing the switch ie. is it serviceable? If replacement needed where am I going to find one for a 2000 model RHD.
thanks
06 Aug 2017 07:27 #183215 by jackonlyjack
The following user(s) said Thank You: jwb
  • jwb
12 Aug 2017 23:54 #183364 by jwb
Replied by jwb on topic Combination switch help needed
So I found a replacement switch from a second hand parts place. Plugged it in to the harness and tried it out before disassembling the steering wheel and all good.
The replacement process was straight forward - disable airbags, pull everything apart and put back together. Just had to go to the store and get a steering wheel puller - unlikely to use that again but it wasn't expensive.
Daughter's Jimny is back on the road.
Time to create page: 0.088 seconds
