Low range 2002 Jimny
  • hatjoepeg
26 Jul 2017 20:47 #182985 by hatjoepeg
Low range 2002 Jimny was created by hatjoepeg
So, high range 4wd is great and has proved that the jimny will go places that my Land Rover won't go BUT it won't select low range
I am new to Jimnys, is this a common problem on a 2002 model or am I looking at major surgery?!
Thanks in advance
27 Jul 2017 07:06 #182987 by jackonlyjack
27 Jul 2017 08:00 #182990 by Busta
Replied by Busta on topic Low range 2002 Jimny
You have to press the stick down and back to select low range. It it's rarely been used then it may be a bit stiff, but there's nothing inside the box that usually gives trouble. As Jack says, if you have a body lift fitted there is a chance the stick fowls the body, preventing it from going into low range.
If there is an issue inside the case then replacement transfer cases are cheap and it's about a 2hr job to swap one in.
The following user(s) said Thank You: hatjoepeg
  • rappey
27 Jul 2017 18:22 #183012 by rappey
Replied by rappey on topic Low range 2002 Jimny
mines a low mileage 2002, probably never even seen low range until i bought it.. As above , you do need to give it a hard yank to get it into low , and a hard shove to get it back out...
Once you've figured that out then there is a simple wire cut mod to get 2wd low !
Time to create page: 0.084 seconds
