Coolant specs...
26 Jul 2017 16:33 #182974
by BGBrit
Coolant specs... was created by BGBrit
Hi all,
Have a look at these specs... Do you think this stuff is fit to use in a Jimny petrol engine... I have in the past used Halford OAT but lost it recently.
online.prista-oil.com/storage/PDS_Eng_AntifreezeLongLife.pdf
Brit in Bulgaria.
Brit in Bulgaria.
26 Jul 2017 16:40 #182975
by Busta
Replied by Busta on topic Coolant specs...
It's less of an issue whether it is compatible with the car as most coolants work in most cars. The main thing to avoid is mixing different types, so if you have used OAT then stick with OAT or something that is compatible with it.
The following user(s) said Thank You: BGBrit
26 Jul 2017 17:01 #182977
by BGBrit
Replied by BGBrit on topic Coolant specs...
Hi Busta,
I believe its the same stuff Halfords call it OAT and Prista call it OA meaning Organic Additive. Just wanted to confirm it with you experts out there
Halfords OAT Antifreeze Concentrate Extra Info
• 5 Year Life
• Suitable for all year round - anti freeze / summer coolant
• Temperature range from +108C / -34C
• Suitable for most vehicles manufactured after 1998
• Silicate free, organic acid technology (OAT) for superior engine protection
• Compatible with all vehicle manufacturers' colours of OAT coolants
• Enhanced corrosion protection
PRISTA® ANTIFREEZE LONG LIFE
products allow extended drain intervals thanks to the special organic additives used in the formulation and their minimum depletion during service. The recommended drain intervals are as follows: • Passenger cars - 250,000 km or 2,000 hours
• 5 Year Life
Time to create page: 0.083 seconds
