Am i being stupid?!
  • Riccy
  • Banned
  • Banned
  • J999 MNY Bashing around Carlisle
21 Jul 2017 18:43 #182904 by Riccy
Am i being stupid?! was created by Riccy
Am i being thick or is there an obvious answer to my 2 questions...
1. Simple query but how do you get to the fusebox in a 2007 jimny? it looks like there are 2, one easy one under the bonnet that does starter-motor, alternator, etc, and one under the drivers knee behind the dash for interior stuff. The bonnet one is easy, but under the dash? Is there an easy way to get it out?
2. Recently changed the clutch. New Excedy job with new release bearing and cover. Works fine, but release bearing is making a annoying rattling/tinkly noise when driving. noise goes if clutch is pressed, so pretty sure its the clutch bearing. Occasionally it makes a worrying snatching noise. I didnt grease the bearing when fitting as its supposed to be factory greased and i didnt want to get grease on the clutch itself. perhaps i should have greased the shaft a bit?
Riccy
  • OllieNZ
22 Jul 2017 08:56 #182916 by OllieNZ
Replied by OllieNZ on topic Re:Am i being stupid?!
Did you apply the supplied grease on the input splines?
22 Jul 2017 10:31 #182919 by BGBrit
Replied by BGBrit on topic Am i being stupid?!
Not easy to access,,, I used a small mirror and light under the dash to locate mine, the cover clips on and off easily and the mini fuses are marked on the inside cover. the fuses were easy enough to pull out.But blood does rush to the head though...
  • Riccy
  • Banned
  • Banned
22 Jul 2017 14:44 #182922 by Riccy
Replied by Riccy on topic Re:Am i being stupid?!
OllieNZ wrote: Did you apply the supplied grease on the input splines?
No, there was no grease supplied in the clutch kit. i do have plenty of different grease, but was unsure if it would spin off and get on the clutch itself
It sounds like im going to have to try and get it off again :-(
  • Riccy
  • Banned
  • Banned
22 Jul 2017 14:46 #182923 by Riccy
Replied by Riccy on topic Am i being stupid?!
BGBrit wrote: Not easy to access,,, I used a small mirror and light under the dash to locate mine, the cover clips on and off easily and the mini fuses are marked on the inside cover. the fuses were easy enough to pull out.But blood does rush to the head though...
hmm thought it would be something daft like that!
23 Jul 2017 05:48 #182937 by facade
Replied by facade on topic Am i being stupid?!
The Jimny fuses are easy.
On my [strike]Renault[/strike] Nissan, the fuses that blow (e.g. sidelights) are in the body control module under the wing.
To get at them, first you take the battery earth lead off as it goes over the top (byebye radio codes and other settings) then you prise the lid up with the fuse panel on the bottom, and use a mirror underneath to see the fuses, as Renault made the cable so short that you can't turn the panel enough to see them.
How I laughed when a 10 second job took half an hour. Imagine doing that in the dark because the lights don't work.....
Time to create page: 0.099 seconds
