leaking gearbox
- rexthecat
14 Jul 2017 19:57 #182742
by rexthecat
leaking gearbox was created by rexthecat
15 Jul 2017 05:27 #182748
Replied by Riccy on topic leaking gearbox
It could be the breather pipe, which is in that area.
Is it a R7me or R72 box (r7me have manual t-boxes, r72 are 2005 on pushbutton tboxes)
I had a leak from the prop itself on the R72 box.
- rexthecat
15 Jul 2017 10:24 #182751
by rexthecat
Replied by rexthecat on topic leaking gearbox
cheers, breather wasn't blocked, thought it may be a leak from the engine, oil level in both box and engine did seem down, thought it might be leaking from the engine into the bell housing but the clutch is clean and dry.
so dunno, put oil in engine and will add a bit of leak stop and fill the box see what happens.
box is the manual one r7
cheers
cheers
17 Jul 2017 18:11 #182805
by facade
Replied by facade on topic leaking gearbox
There is a rubber bung just pushed in a hole up at the top on the passenger side by the selector housing that falls out, and oil then comes out.
Not sure why it isn't a bolt if it is supposed to be a seal...
The following user(s) said Thank You: rexthecat
Time to create page: 0.091 seconds
