Dismantling wiper arms
However, there is a strong spring in the rear section of the wiper arm, which I need to remove if I want to be able to clean it fully and then repaint it without any obstructions.
Has anyone managed to successfully remove and reinstall this spring? It is quite strong. I am afraid if I remove it, that I won't be able to reinstall it.
Also, what tool to use to remove and reinstall it without scratching the spring and/or the wiper arm in the process? The screwdriver induces a high risk of that.
- rappey
Bosanek wrote: I need to repaint my front wiper arms because the paint peeled off and shiny metal is exposed. I am afraid they are going to rust soon otherwise.
[/quote
If the paints peels off and the steel is shiny then surely that points to the arms being stainless steel ?
I would just mask around them and spray them from an aerosol.. Saves a lot of hassle..
[/quote
+1.................and maybe use Hammerite.
- Thank you received: 2004
Using pliers often ends in tears as they slip off at some point.
