Help please>> M16A swap engine not working
  • Mr.m.y
07 Jul 2017 08:18 #182527 by Mr.m.y
Replied by Mr.m.y on topic Help please>> M16A swap engine not working
i swap the cover and indignation coil of m13a
now the problem i have petrol and low spark
07 Jul 2017 20:13 #182539 by Keithy
Did you check the engine is grounded?
Put a multimeter set on DC Volts from the negative terminal on the battery and the other to the engine block....anything over 0.5V I'd reground it.
Do the sensors have the same resistance value as the originals?
The following user(s) said Thank You: Mr.m.y
  • Mr.m.y
09 Jul 2017 14:06 #182569 by Mr.m.y
Thankyou Keithy
There was different in the trigger wheel
m13a 31 teeth
m16a 2014 vvt sport 30 teeth
any recommendation
09 Jul 2017 20:03 #182584 by Keithy
Damn that's hard cheese old chap....swap the trigger wheel?....it'll fit but it means dropping the sump removing the crank and 3 allen socket heads....it's a whole lot of work but it should be able to be managed by the ecu then.
  • Mr.m.y
12 Jul 2017 13:38 #182674 by Mr.m.y
we swap the trigger wheel
and the engine work great
thankyou all
12 Jul 2017 17:27 #182679 by Keithy
Mr.m.y wrote: we swap the trigger wheel
thankyou all
Nice one I'm pleased for you!
Time to create page: 0.366 seconds
