spung a leak
- Thank you received: 1936
05 Jul 2017 17:05 #182494
Replied by Lambert on topic spung a leak
Yeah the red pipes are for wading.
- OllieNZ
05 Jul 2017 17:37 #182495
by OllieNZ
Replied by OllieNZ on topic Re:spung a leak
Line with oil on is probably the power steering line. There's a pressure and return from the pump/reservoir on the l/h side of the engine to the steering box on the r/h chassis rail. When mine was leaking in that general area it turned out to be the crank seal. You really need to ID the fluid to help narrow down the leak. Gear oil, engine oil and ps fluid are all very different from each other in smell and feel.
- mattt
05 Jul 2017 18:18 #182496
by mattt
Replied by mattt on topic Re:spung a leak
well i can go in deep puddles great !
I'm really no expert when it comes to oil ( or general spannering ) but I'm pretty sure its not gear oil. can't see any oil above where the corner of that pipe is in pic but its hard to tell . guess i will try and have a poke around over the weekend if not off to the garage to have my pants pulled down lol
07 Jul 2017 14:28 #182533
I've never been able to identify oils especially when they have dribbled down past all the dirt and muck. My only way is to put paper under the car to see where the drip is ending up. And to make it worse antifreeze fools me too........hopeless aren't I.:blush: :blush:
Replied by helijohn on topic Re:spung a leak
OllieNZ wrote: Gear oil, engine oil and ps fluid are all very different from each other in smell and feel.
- mattt
08 Jul 2017 16:45 #182549
by mattt
right had a look its defiantly power steering fluid its now below minimum , and turning the wheel makes a horrible noise !
can't get my fat head right in there but it seems theres only fluid on that corner in the first pic ,nothing above but theres no joint there or obvious leaking point ?
I'm going to get some fluid and top it up just to see if the noise stops . anyone got a rough idea what recon power steering unit will run me ?
- mattt
08 Jul 2017 16:55 #182551
by mattt
quick google says recon about 180 . sound about right ?
also just seen some power steering stop leak fluid anyone used this ?
sorry for all the dumb questions just don't wanna get my pants pulled down
Time to create page: 0.150 seconds
