spung a leak
- mattt
05 Jul 2017 08:43 #182483
by mattt
spung a leak was created by mattt
my front diff seems to be leaking ! only had a quick look seems to be wet on the top and there for all over mainly the front . this a common problem / easy fix ? or is it usually a garage job ?
be grateful for and guidance
thanks
thanks
- mattt
05 Jul 2017 08:45 #182484
by mattt
Replied by mattt on topic spung a leak
the wet patch in second pic was after not moving for over a week
- Thank you received: 1934
05 Jul 2017 09:19 #182485
Replied by Lambert on topic spung a leak
Does the oil have a fairly pungent smell? Just seems odd leaking from the top. It could be something above that is dripping onto the diff rather than the actual diff leaking have a good look on the engine for signs of a failure.
05 Jul 2017 09:23 #182486
Replied by Daniel30 on topic spung a leak
check your other fluid levels
- mattt
05 Jul 2017 09:41 #182487
by mattt
good point fellas, does seem more like engine oil not stinky gear oil . i will open the bonnet and have a look later
(why is it always easier to think rationally when fixing someone else 's problem haha )
- mattt
05 Jul 2017 16:58 #182492
by mattt
ok so there seems to be a pipe with black oil on it that runs under and across the the bottom of the rad . can't see where it comes up ? engine oil and transmission oil seem ok
side note last two pics , is the red pipe a breather kit so i can go in big puddles ? looks like something similar on rear as well
Time to create page: 0.210 seconds
