Help!!!! ABS Light ....
  • ZukracerV6
26 Jun 2017 09:34 #182285 by ZukracerV6
Help!!!! ABS Light .... was created by ZukracerV6
Morning,
I am starting to lose the will with the ABS light on the Surf. No matter what I do, I cannot get the ABS light to go off when the engine is running. I have checked and tripled checked all of the connections, the brakes physically work great but without the ABS. The light just stays permanently on.
The vehicle is 95% finished but I cannot not pass the IVA test with the ABS light on!!!!
I have spent hours researching the diagnostic trouble codes and hours lying under the dash trying to find the connector behind the glove box. It simply does not exist! Does a 2009 Jimny even have this connector? Can someone post some pictures if they have a 2009 or similar aged Jimny showing this connector? None of the workshop manuals I have relate to the wiring from a 2009 Jimny.
Really need some help!
Thanks
Sam
26 Jun 2017 13:13 #182288 by Keithy
Replied by Keithy on topic Help!!!! ABS Light ....
Is it not to the right of the bonnet release? pointing straight down.
  • ZukracerV6
26 Jun 2017 15:50 #182294 by ZukracerV6
Replied by ZukracerV6 on topic Help!!!! ABS Light ....
There is a white 3 pin connector on the drivers side with 2 black cables and 1 white but when I have had a fiddle with it, I just blew the fuse for the radio!
26 Jun 2017 16:03 #182295 by Keithy
Oh 3 pin I have no idea what it is.....I thought you wanted the OBD connector.
  • ZukracerV6
26 Jun 2017 17:40 #182304 by ZukracerV6
No, I'm looking for the ABS diognositc connector.
I've had a mate from a garage call around with a reader and its picked up one error code from the ABS system C1016 brake circuit? Any ideas?
26 Jun 2017 18:11 #182308 by Keithy
Google says brake light switch.....my brothers ABS warning light was his bulb :D
Time to create page: 0.094 seconds
