Front wheel bearings.
- 1066Boy
12 Jun 2017 16:54 #181932
by 1066Boy
Front wheel bearings. was created by 1066Boy
Hi all. I have to change the N/S/F wheel bearing soon as its getting rough. Is it worth doing both sides at the same time?
The O/S/F one is ok at the moment but both are the original ones.
12 Jun 2017 18:26 #181938
by Busta
Replied by Busta on topic Front wheel bearings.
I've generally found NS bearings don't last as long as OS. I wouldn't replace the other side until it needs doing.
- 1066Boy
12 Jun 2017 18:47 #181946
by 1066Boy
Replied by 1066Boy on topic Front wheel bearings.
Ok Busta, thanks.
28 Jun 2017 10:42 #182358
by Bosanek
Replied by Bosanek on topic Front wheel bearings.
You will NOT be able to replace the front wheel bearing without a special tool to undo the locking nut. Martin sells a compatible replacement tool in his store.
- 1066Boy
28 Jun 2017 15:16 #182364
by 1066Boy
I have one already thanks.
- TomDK
28 Jun 2017 17:22 #182368
by TomDK
Not exactly true.
Easily done with a hammer and a rounded chisel or similar. I always use this method as I don't own that special tool.
Replied by TomDK on topic Front wheel bearings.
Bosanek wrote: You will NOT be able to replace the front wheel bearing without a special tool to undo the locking nut. Martin sells a compatible replacement tool in his store.
Not exactly true.
Time to create page: 0.096 seconds
