CV joint failure?
- rappey
11 Jun 2017 18:15 #181925
by rappey
CV joint failure? was created by rappey
Off roading with the usual landrovers at slindon today... Winching them out of holes, picking up the bits that fall off on the way home etc,lol, but today was my turn for a little fail !
Was in 4 wheel drive on reasonable terrain, then heard a click click click noise for around 5-10 secs... like a uj joint... But then it stopped and i carried on until i came to a slope and just couldnt get up ? 4wd light was lit, could hear the vacuum hubs engage/disengage when selected... but only rear wheel drive..
Steering wont turn much past half way to the left, and brake pedal seems to have more travel? so could this be a broken cv joint, and which side?
Is there any way i can test for this..
Andy....
Andy....
11 Jun 2017 18:18 #181926
by j999pre
Grey pick up Jimny
Replied by j999pre on topic CV joint failure?
Sounds like CV. Take the steering bar off the driver's side and try and move the hub lock to lock. If it doesn't move as it should it will be that side. If it does then it will be the other.
Grey pick up Jimny
The following user(s) said Thank You: rappey
Time to create page: 0.099 seconds
