ORA Chassiss Mount Guard
10 Jun 2017 18:19 - 10 Jun 2017 21:08 #181908
by HUN
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
ORA Chassiss Mount Guard was created by HUN
Hello Guys,
I will take my Jimny to a garage in August for upgrading the suspension and changing bushes, bearings & seals wherever it's needed. Fitting of ORA chassis guards is part of this job and I want to make sure they follow the factory instructions (even if it's obvious what to do). Has anyone ever come across the genuine fitting instructions from ORA? As far as I know they used to supply colorful PDF documents with photos of each step for their products but I could not find to download it anywhere. ORA's Product Code is: SMG100
Any help much apprecipiated.
Regards, Gabor
Regards, Gabor
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Last edit: 10 Jun 2017 21:08 by HUN.
- X8GGY
12 Jun 2017 11:36 - 12 Jun 2017 11:37 #181929
Replied by X8GGY on topic ORA Chassiss Mount Guard
Hi, I've had a look and can't locate and fitting instructions for them, but...
They just slip over the existing chassis mounts, with the thick spacer washers in-between the guard and the mount, then use the slightly longer M12 x 120mm bolts to go through instead of the existing M12 x 100mm. The smaller bolts (M8 x 25mm) then go through the small hole (they'll need to drill through the chassis mount underneath, the long triangle slots are there to get a spanner onto the nut inside...
And the same on the front...
Last edit: 12 Jun 2017 11:37 by X8GGY.
- X8GGY
12 Jun 2017 11:52 #181930
- Thank you received: 2004
12 Jun 2017 17:25 #181933
Replied by Lambert on topic ORA Chassiss Mount Guard
I hate to say this but it looks a bit raw under there?or is it just red clay you haven't cleaned off?
- X8GGY
12 Jun 2017 18:00 #181934
That'll be some of Oldhamshire stuck to it
11/60 wrote: I hate to say this but it looks a bit raw under there?or is it just red clay you haven't cleaned off?
13 Jun 2017 04:18 #181959
Ah that's ok then.
Time to create page: 0.107 seconds
