Engine M13AA rattle after overheating
- speedbr
05 Jun 2017 18:28 #181770
by speedbr
Engine M13AA rattle after overheating was created by speedbr
First thanks for accepting me here. I look for help a long time ...
I have a Jimny 2011( engine m13aa ) with 46000 miles and unfortunately my engine overheated.
The problem was a hole in the radiator that caused me to lose all the water very fast ....
After this episode my engine rattle ( 2000-3000 rpm ) only with high load ( uphill ) and engaged and when the engine is hot. In standby everything is normal.
I read a lot about detonation, pinging, timing point and no one can tell me where is the problem.
Analyzing the problem I found the melted detonation sensor and i replace it. If i use a better gas the rattle decreases a lot. There is not water in the oil and i made the compression test.
Maybe some other sensor burn with overheating? Do I need to open the engine to solve? The engine run out of time?
Thanks a lot for any help.
07 Jun 2017 17:07 #181818
by asypeer
Replied by asypeer on topic Re:Engine M13AA rattle after overheating
Does it lose coolant ?
- speedbr
07 Jun 2017 20:30 #181821
by speedbr
Replied by speedbr on topic Re:Engine M13AA rattle after overheating
Yes, i lose all coolant very fast. The temperature went up quickly and I stop the car. This moment the engine stop too. There isnt error in ECU, only problem is the rattle under high load, its so strange.
08 Jun 2017 08:22 #181840
by Keithy
Replied by Keithy on topic Engine M13AA rattle after overheating
I think asypeer meant "does it lose coolant...now" but it sounds like a bearing gone to me....if it got hot enough could be small end?
08 Jun 2017 12:10 #181848
by asypeer
Check also your coils, overheating might burn them
- speedbr
08 Jun 2017 13:37 #181852
by speedbr
Replied by speedbr on topic Engine M13AA rattle after overheating
Ohh, thanks Keithy ! After change the radiator the coolant level is normal. For check this i made a compression test and the gasket is fine.
Maybe the problem is bearing, but if it is gone i think the noise would occur all the time regardless of the load. That intrigues me ...
Thanks for your help.
Time to create page: 0.094 seconds
