Rear diff slipping
- liammaclean
04 Jun 2017 16:52 #181759
by liammaclean
Rear diff slipping was created by liammaclean
I was off road about two months ago and the rear prop with turning with a loud noise as though the pinion was slipping, with no turning of the wheels. I drove it home without the rear prop and kept it in four wheel drive to keep front wheel drive. I did this as I thought the rear diff had packed in and would not drive anymore.
With having the bigger wheels I took the opportunity to replace both of the diffs with a 4.3 diff set, which geared the drive train down a bit. When taking out the old rear diff there didn't appear to be any damage of any kind, even though it seemed like the pinion was slipping. Once back on the road there was a horrific juddering form the transfer box when I backed off the accelerator. I managed to get another transfer box to swap the old one for and it was running fine after that with no issues after that.
Went off road again last night and eventually got stuck. When trying to get out, again the new diff on the rear started the same thing, by slipping with no turning of the wheels. Having thought when the old one was removed there was no damage, it may actually drive on the road. Once back on the road it drove no bother like it did before it was off road. However the juddering has started again from the transfer box, but not nearly as bad as before.
I started to think the transfer box issue was the chain slipping, but I do not know why it would be. I decided to disassemble the old transfer box to see if there were any signs of this, but there were none. I am planning fitting an SJ413 transfer box now as the current transfer box isn't working porperly.
Any help or explanation as to why this is happening would be appreciated.
05 Jun 2017 07:23 #181764
Replied by Riccy on topic Rear diff slipping
Mine had a mysterious noise when i bought it. it used to make a horrible grinding noise when reversing around a uphill corner.
turned out to be the front bumper catching on the tyre a bit! Did sound like it was coming from underneath
Time to create page: 0.085 seconds
