Not engaging 4WD
01 Jun 2017 15:48 #181671
by furo
Not engaging 4WD was created by furo
Hi folks,
I'm looking for some advice. For a while now my Jimny (2004) hasn't been engaging 4WD. The dash light comes on when the lever is pulled, but the front wheels aren't powered. Today I installed AVM manual hubs in the hope that would solve the issue, but it doesn't seem to have helped. When I pull the lever now sometimes the light comes on and sometimes it doesn't, but there's no change in steering feel etc, so I don't think it's engaging.
Any ideas what the problem could be?
Many thanks
Many thanks
01 Jun 2017 15:51 #181672
by furo
Replied by furo on topic Not engaging 4WD
I should add that a while back my Jimny stopped engaging 4WD after the vacuum pipes corroded, but that time the dashboard light wouldn't come on at all. So I'm guessing this is something else.
- Iaitoo
01 Jun 2017 17:25 #181674
by Iaitoo
Replied by Iaitoo on topic Not engaging 4WD
Lock the hubs, start the engine, put it in 4wd and then jack up one of the wheels and check if it is locked in. You won't get a 4wd light now that you have removed the vacuum system. I didn't think mine was engaging, but it actually was. Don't change the steering feel that much
01 Jun 2017 18:40 - 01 Jun 2017 19:27 #181678
by furo
Thanks @laitoo! I just did that - with the manual hubs locked the lifted wheel moves about 5-10 degrees but no further. With the hubs unlocked it rolls freely. Left and right both the same.
So does that mean that 4WD is engaging as it should?
Last edit: 01 Jun 2017 19:27 by furo.
- Iaitoo
01 Jun 2017 20:45 #181682
by Iaitoo
Yes it does
You need to rig the light to make it stay on, after a manual hub conversion. There is a guide on here some where. Nice to do if the flashing light makes you crazy
01 Jun 2017 20:59 #181683
by furo
That's a huge relief, thank you very much!
Time to create page: 0.129 seconds
