Jimny diff rebuild.
  • Hastiekid
29 May 2017 08:33 #181625 by Hastiekid
Jimny diff rebuild. was created by Hastiekid
After a couple of years of abuse my ARB air locker rear diff has play on the pinion shaft so I've whipped it out for a rebuild. On examination it could do with a pair of pinion bearings and a seal. The carrier bearings are fine so they are going back in. I'm using a solid sleeve rather than the crush sleeve to try and strengthen it up a bit. The air locker itself is fine so its going in with new seals.
Now........ though I built it myself in the first place I cant for the life of me remember how I went about setting the preloads etc. Is there any information about or articles documenting the process of rebuilding a Jimny diff or even just preload information? How do you go about checking pinion preload with a spring balance and what should the reading be? Are the settings for preload different depending on whether the bearings are new or used?
Any help with this would be much appreciated.
Cheers
Ian
29 May 2017 09:31 #181628 by Riccy
Replied by Riccy on topic Jimny diff rebuild.
I was just looking at this in the workshop manual for installing diffs...
i think this is what you want:
  • Hastiekid
29 May 2017 16:22 #181639 by Hastiekid
Replied by Hastiekid on topic Jimny diff rebuild.
Thanks Riccy, thats exactly the sort of information Im after but I could do with the whole thing.
29 May 2017 18:14 #181641 by Riccy
PM
Time to create page: 0.091 seconds
