Rattle in 4th gear only?
- Justin83
21 May 2017 08:03 #181374
by Justin83
Rattle in 4th gear only? was created by Justin83
Hey all, depressing times again, the 06 Jim has now decided to rattle when under load in 4th and to a lesser extent 3rd gears...
It's kinder like a chain noise or like big end bearings on there way out. It's definitely gear related as it makes no noise at all in 1st,2nd and 5th.
I've done the search thing and it sounds expensive, gearbox rebuild time at 60k miles!??
I had a look in the dark last night for any obvious leaks in the hope that it's just low fluid...
Fast becoming a bad experience with this jimny when our old 04 plate was so well behaved!
- Justin83
21 May 2017 09:17 #181377
by Justin83
Replied by Justin83 on topic Rattle in 4th gear only?
Well there is a bit of oily residue around the usual gearbox to transfer gearbox seal... Fingers crossed a top up quietens it down but I'm not optimistic...
Are the third and fourth gears located higher in the box, or any other reason only those will make noise if the fluid gets low?
The car isn't off roaded other than a few light greenlanes.
The way the noise seemed to suddenly come on is worrying too.
Time to create page: 0.070 seconds
