Crank pulley change.
07 May 2017 08:31 - 07 May 2017 08:38 #180985 by Busta
Crank pulley change. was created by Busta
I had noticed a bit of extra noise coming from the auxiliary belts on my Jimny. The belts were in good condition and were tensioned correctly however the crank pulley seemed to have a bit of a wobble to it. Here it is in slow motion:
So it was crank pulley change time! After doing the job, I now know there is room to do it without removing the radiator. But it certainly helps to have a clearer view of things with it removed, so I drained the coolant and took it off.
Once the two belts are removed the next challenge is undoing the bolt in the middle of the crank pulley. I tried with the car in 5th gear and the handbrake on, but there is too much spring in the system to get any amount of force on it with a breaker bar. So plan B: wedge the bar against something solid in the engine bay and flick the starter.
My 18 inch breaker bar nested nicely against the wing as shown:
One flick of the key and the engine turned over with a slight bang as the bolt loosened off. Easy!
Once removed, I could see fine rubber dust inside the crank pulley and saw the rubber part had delaminated for nearly 1/2 of the diameter. I think I caught it just in time.
The replacement pulley I had to hand was from the low mileage Liana that had previously donated its 1.6 engine to my old silver Jimny.
The eagle eyed amongst you will notice the Liana pulley is slightly different to the Jimny one- The front part that drive the power steering (and aircon if you have it fitted) is the same diameter (145mm) as the rear part, rather than stepped 145/125mm arrangement of the original. This meant I needed a longer belt. A bit of GCSE maths told me it should be 30mm longer than the standard 4pk850, so I popped to Wilco, my local friendly motorfactors, and picked up a 4pk885. The advantage of the bigger Liana pulley is there is a bit more oil flow to the power steering at low engine speeds, which seems to have lightened it up a little when shunting about.
The old power steering belt (4pk850) was in better shape than the alternator belt (4pk835), so I re-fitted it to the alternator side and the adjuster easily took up the slack of the longer belt. It's worth noting that you can use the same belt on both sides. Handy if you like to keep a spare.
I refitted the radiator and strained the coolant through an old rag as I poured it back into the system. Whilst running the engine for 15 minutes with the heater on, and periodically squeezing the top hose to release trapped air, I was able to get nearly all the coolant back in the system. I topped up the expansion tanks with what wouldn't fit in the rad.
Job done! Aside from a little trip to the motor factors, it took a little over an hour. Leaving the radiator on would have saved another 15 minutes or so but would also mean crawling about on the floor and struggling to access the 8mm allen bolt that the alternator pivots on.
I hope this little write up will help anyone else tackling the same job or messing around with belts and pulleys.
Last edit: 07 May 2017 08:38 by Busta.
The following user(s) said Thank You: Keithy
  • Daniel30
08 May 2017 09:55 #181042 by Daniel30
Replied by Daniel30 on topic Crank pulley change.
Great write up Busta B)
  • Young Pretender
08 May 2017 14:02 #181054 by Young Pretender
Replied by Young Pretender on topic Crank pulley change.
Thanks Busta this will help me sometime soon no doubt. It took me 3-4 hours to replace my rad lol :blush:
08 May 2017 14:18 #181055 by Keithy
Replied by Keithy on topic Crank pulley change.
I wondered about the pulley fit.....now I know.
Cheers Busta!
Time to create page: 0.085 seconds
