Rear Diff Plug and debris
- grumyoldjoe
- Elite Member
- Thank you received: 19
04 May 2017 12:14 #180894
by grumyoldjoe
Wine improves with age.
Rear Diff Plug and debris was created by grumyoldjoe
Just changed the rear diff oil and have noticed the metal debris and gunge on the plug.
Is this amount of debris normal for a 30k miles Jim ?
04 May 2017 19:42 #180914
by facade
Replied by facade on topic Rear Diff Plug and debris
Paste like gunge, yes.
Metal swarf no. Possibly a bearing on the way out, or one worn out previously and the oil hasn't been changed since.
Not much you can do really except keep an eye on it, and if you see a rear diff at a bargain price, pick it up in case yours starts getting noisy.
- grumyoldjoe
- Elite Member
04 May 2017 20:08 #180916
by grumyoldjoe
Replied by grumyoldjoe on topic Rear Diff Plug and debris
Cheers
Its the first oil change since new (2013) so has not had bearings changed.
Dont think the first 3 yrs services I had done via dealers included dropping the diff oils.
Will drop the oil again in the summer and see whats present.
07 May 2017 11:57 #180991
by facade
If it is the first oil change ever, I'd not worry.
Modern cars are so poorly thrown together using bits that were blindly made by machines (probably out of the S.U.N.* bin) that pieces shave off all over the place in the first couple of thousand miles, changing the oils is supposed to remove them at the first service.
*scrap until needed- the place where they put the rejects until the line runs out, then they use them anyway.
Time to create page: 0.079 seconds
