Higher output alternator
  • ME13OSE
01 May 2017 09:29 #180758 by ME13OSE
Higher output alternator was created by ME13OSE
I know this has been chatted about loads, and searching "alternator upgrade" on the forum doesn't really answer my question.
Is there a straight swap alternator unit for the 1.3 16v non vvt engine that will give you a higher output? If yes, which vehicle and year etc does it come from.
03 May 2017 10:08 #180852 by yakuza
Replied by yakuza on topic Higher output alternator
I am not sure about the earlier models but my '05 jimny alternator is bigger than other (1,3) suzuki alternators i got.
If you are planning to go scavenging in a junkyard you could check what is inside cars with more electrical equipment and has larger batteries than the jimny. Suzukies with 1.6 and bigger engines will most likely have larger generators.
When putting a Liana engine in my car i did not change the alternator bracket so Liana would probably fit ok.
It could be that it is easier to modify brackets to fit other alternators with high output, than to find one that is a straight fit.
  • ME13OSE
08 Oct 2017 20:37 #184981 by ME13OSE
Replied by ME13OSE on topic Higher output alternator
Just to add to this. I've just completed the alternator upgrade on the Jimny, my choice was the 150A unit fitted to the Suzuki SX4. In and working like a dream. Also added in an idle pulley to increase the surface area the belt has on the alternator main pulley during heavy draws such as winching.
09 Oct 2017 06:49 #184985 by zukebob
Replied by zukebob on topic Higher output alternator
If you have time, would love to see some pictures.
  • TomDK
09 Oct 2017 07:09 #184986 by TomDK
Replied by TomDK on topic Higher output alternator
ME13OSE wrote: Just to add to this. I've just completed the alternator upgrade on the Jimny, my choice was the 150A unit fitted to the Suzuki SX4. In and working like a dream. Also added in an idle pulley to increase the surface area the belt has on the alternator main pulley during heavy draws such as winching.
Was it a direct bolt-on? What about wiring?
  • ME13OSE
09 Oct 2017 15:18 #185003 by ME13OSE
No, it's not a direct bolt on. 150A units use a much bigger casing. Every part of the wiring has to be altered in one way or another. Not a simple DIY job.
Time to create page: 0.089 seconds
