How to remove this brake line?
  • 04JimnyNorwegianGuy
22 Apr 2017 17:01 #180484 by 04JimnyNorwegianGuy
How to remove this brake line? was created by 04JimnyNorwegianGuy
There is no nut on the upper line??
Im trying to assemble the ext. lines wich came with the trailmaster lift kit
22 Apr 2017 17:15 #180485 by jackonlyjack
If that's the one under front wing left hand side
it connects higher up on inner wing
the part in picture is not the connecting part that just holds the clip
Jack
22 Apr 2017 17:49 #180486 by Riccy
If its the same as my trailmaster 2" kit then it comes with 2 hoses, both the same
They are for the rear. I got a garage to fit mine (scared of fiddling with brakes, only 1 was needed on my 2007), so i dont know but it looks like the top hose in your red circle has something inside it, so maybe its a push into the hose fitting? (dont know the proper name for it).
22 Apr 2017 18:51 #180491 by 04JimnyNorwegianGuy
Replied by 04JimnyNorwegianGuy on topic How to remove this brake line?
I think I'll remove this post because I've figured out I've got wrong kind of extended brake lines. They are not supposed to be connected there but further up .....Lines i have got must be to short :-(
22 Apr 2017 23:04 #180499 by 04JimnyNorwegianGuy
Perhaps I can mount the new extende line (even though its a wrong one) to the existing original line with this assembly?
Time to create page: 0.101 seconds
