Vented front disc setup.
- Justin83
15 Apr 2017 07:43 #180260
by Justin83
Vented front disc setup. was created by Justin83
Hey all Keithy mentioned a setup using jimny diesel discs and vitara lwb callipers, can anyone tell me what year and model callipers please?
Just sorted a dw problem after two sets of discs in 5k!! Looking for something more reliable than the weedy solids.
15 Apr 2017 08:36 #180262
Replied by Riccy on topic Vented front disc setup.
No eBay APP ID and/or Cert ID defined in Kunena configurationThese are the discs - for a diesel jim...
and you need calipers/carriers and pads from a 2001-2005 grand vitara 1.6 i think.
Ive just ordered all of above recently and waiting for it all to arrive. Will see if it fits that easily
Riccy
Riccy
- Justin83
15 Apr 2017 18:23 #180268
by Justin83
Replied by Justin83 on topic Vented front disc setup.
Cushdy, cheers pal.
- NIKOS OETA
17 Apr 2017 20:53 #180352
by NIKOS OETA
Replied by NIKOS OETA on topic Vented front disc setup.
calipers/carriers from 5doors 1.6 vitara fits correctly.
19 Apr 2017 23:26 - 19 Apr 2017 23:30 #180417
Replied by yakuza on topic Vented front disc setup.
Vitara year model from 1992 to 1998 approx. do not remember accurately. I got these for another project and test mounted in the garage. fits ok and even the vented disc from same car allmost fits. center hole only slight difference, can be turned/machined to fit. Dieseljimny discs probably fits much better.
bleed valve is not in top position when vitara calipers is mounted on the Jimny, so remember to bleed brakes with calipers loose and positioned so the bleed valves is upright.
Bracket for the caliper is also the same as on SJ. Same pads on SJ as Jimny, allmost same discs on early models(?), only center hole slightly different on my 05 car.
Last edit: 19 Apr 2017 23:30 by yakuza. Reason: typo
Time to create page: 0.091 seconds
