2006 jimny P140 Fault Code.
  • Ally
06 Apr 2017 13:37 #179963 by Ally
2006 jimny P140 Fault Code. was created by Ally
Can someone confirm to me which 02 sensor is Bank 1 sensor 2, Sometimes get engine check light coming on when off road and engine is idling.
When I put scanner on it comes up P140 sensor CKT no activity bank 1 sensor 2. And if engine is shut down for a while then started light is out but code still there. .
06 Apr 2017 20:32 #179990 by Scot The Sniper
type the trouble code into google and google will tell what one it is, also i have took ones out of customers cars and cleand them up and it seems to work on most of them give that a go first before you buy a new one
  • Ally
07 Apr 2017 06:33 - 07 Apr 2017 06:34 #180000 by Ally
Replied by Ally on topic 2006 jimny P140 Fault Code.
Scot The Sniper wrote: type the trouble code into google and google will tell what one it is, also i have took ones out of customers cars and cleand them up and it seems to work on most of them give that a go first before you buy a new one
The code says bank 1 sensor 2 , so is that manifold cat or exhaust cat.
Last edit: 07 Apr 2017 06:34 by Ally .
07 Apr 2017 15:21 #180025 by Jezz
Replied by Jezz on topic 2006 jimny P140 Fault Code.
A Jimny only has a bank 1 as it's a four pot in line engine and not a v6/8/12 type engine with two banks of pistons.
I would think sensor one would be the manifold and sensor two the cat. If i've got that completely wrong i'm sure someone will be along shortly to tell me so.
It's been fettled just a tad.
Time to create page: 0.083 seconds
