swivel pins
  • little boghopper
30 Mar 2017 14:18 #179769 by little boghopper
swivel pins was created by little boghopper
hi all, this is probably in the wrong place, hey hoo , stressed! :( , ive just come back from my mot and she has failed on OS/F tractor joint.
they wrote the following on a piece of paper telling me they were suzuki only parts.
TRACTOR JOINT 2 SWIVEL PINS WITH BEARING +OIL SEAL + GREASE, OK IF ABS BOLT COMES OUT.
i have been sat here for over an hr and now confused. its the king pins and bearings that need replacing and the inner oil seal right? do you really need to change the swivel pins too and the large dust/sand seal on the swivel itself? any help on this would be greatly appreciated, then ill buy all the parts from the jimny shop and then work out how or who fits em!! so far ive only changed all the diff and gear oils plus coolant etc, dont think id like to tackle this one, many thanks in advance. does anyone know a good jimny service spot nr Richmond Yorkshire. cheers Liam.
30 Mar 2017 14:34 #179770 by mlines
Replied by mlines on topic swivel pins
Rarely need to change the pins, usually just the bearings.
Straight forward job for anyone with a reasonable tool box.
www.bigjimny.com/store/kingpin-bearing-k...zuki-jimny-koyo.html
  • TomDK
30 Mar 2017 14:38 - 30 Mar 2017 14:39 #179771 by TomDK
Replied by TomDK on topic swivel pins
Tractor joint.. ?
Is that the CV Joint?
If so, you'll probably need to change kingpin bearings and the inner oil seal. Takes a little time to do. But fairly straightforward.
Edit: .. Mr Lines was a tad faster :side:
Last edit: 30 Mar 2017 14:39 by TomDK.
  • little boghopper
30 Mar 2017 14:59 #179773 by little boghopper
Replied by little boghopper on topic swivel pins
cheers guys, so just the bearings , is it a problem getting the abs bolt out? or can this be left in? then its greasing the bearings and packing the inside?
ive watched your video a few time s now martin , i,ll order the parts from you and set someone else at it as i,m lacking tools and doing it before!!
LIAM
  • little boghopper
30 Mar 2017 15:26 #179774 by little boghopper
more questions!! in your step by step guide martin you say 100ml of grease? is this the waterproof blue one packed inside the knuckle before you re install the drive shaft?
30 Mar 2017 19:45 #179782 by mlines
Replied by mlines on topic Re:swivel pins
The 100ml is for the CV and around the swivel seal, it's not a large amount. Most people over fill it
Sent from my Nexus 6P using Tapatalk
