Fitting A Handsfree Radio Question
22 Mar 2017 12:24 #179491
by bryn
Fitting A Handsfree Radio Question was created by bryn
I'm about to fit a blue tooth hands free and will be using a ISO SOT lead which fits into the back of the radio. I no longer have the radio code and if I'm quickly disconnecting the jack from the back of the radio and then reconnecting will I need the radio code.
Thanks for looking and if you have any tips on fitting a hands free (will probably go for a parrot) then they are gratefully received
bryn
bryn
- Thank you received: 706
22 Mar 2017 15:42 #179503
Replied by jackonlyjack on topic Fitting A Handsfree Radio Question
I would use a spare battery and two wires to keep voltage
i'm sure any loss in volts will leave you needing the code
Jack
Jack
22 Mar 2017 18:17 #179519
by Busta
Replied by Busta on topic Fitting A Handsfree Radio Question
What about a bluetooth FM transmitter? They plug in your cigarette lighter and you tune the radio into the same frequency as the transmitter. No wiring involved, compatible with any FM radio.
22 Mar 2017 19:59 - 22 Mar 2017 19:59 #179524
by bryn
Replied by bryn on topic Fitting A Handsfree Radio Question
Thanks for the suggestion busta but I was looking for something more permanent
bryn
bryn
Last edit: 22 Mar 2017 19:59 by bryn. Reason: x
23 Mar 2017 12:45 - 23 Mar 2017 12:48 #179560
by Rhinoman
Replied by Rhinoman on topic Fitting A Handsfree Radio Question
Maybe. The radio code wasn't activated by default so many Jimnys don't have a problem. You will need an adapter to connect an ISO lead to a Jimny radio. I'm not entirely sure what it is you plan to fit - you may find that the old Suzuki radio doesn't support it.
Last edit: 23 Mar 2017 12:48 by Rhinoman.
25 Mar 2017 16:14 - 25 Mar 2017 16:15 #179632
by bryn
Thanks for your suggestions and help. I fitted the parrot hands free and its a piece of cake. I did use an ISO lead which initially is a little baffling considering the amount of plugs and sockets but is very easy (with a little youtube help).
I had quotes to fit from £50 to £100 but once I got the front console off which is done by taking out the ashtray and undoing 3 screws it took me about 15 minutes and a few tie wraps.
My jimny is a 2007 and the ISO lead fits 2003 on wards and the cost was £14 of eBay.
I did not need the radio code.
bryn
bryn
Last edit: 25 Mar 2017 16:15 by bryn. Reason: x
Time to create page: 0.098 seconds
