Snorkel
- paradox1001
21 Mar 2017 16:10 #179453
by paradox1001
Snorkel was created by paradox1001
I'm wanting to fit a snorkel to my jimny
I've see a few different ones on eBay under£100
I was wondering what type others have fitted
Is there and preffered ones that are better than others and is there any I should be avoiding
- Thank you received: 706
21 Mar 2017 16:26 #179454
Replied by jackonlyjack on topic Snorkel
The only one i would personally avoid is the one supplied by
LR Challenge 4x4 as it's got a fixed head so if you smash it you simply can't just fit a new one
all the different makes are made of same material LLDPE
so make your own choice
Jack
Jack
The following user(s) said Thank You: paradox1001
- DINGLE287
22 Mar 2017 00:38 #179481
by DINGLE287
Replied by DINGLE287 on topic Re:Snorkel
I'm also currently looking at snorkels available. Has anybody used the short version. Are they harder to fit and pipe up? I'm tempted to go for one as they look better than the standard one's that run down the wing. But there isn't much info offered to the differences and regarding fitting
Sent from my SM-N9005 using Tapatalk
22 Mar 2017 07:06 #179483
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Re:Snorkel
I have a short one for sale. You need to provide your own piece of flexi hose from snorkel to airbox.
Grey pick up Jimny
- DINGLE287
22 Mar 2017 12:50 #179494
by DINGLE287
Is it easy enough to run the pipe behind the wing, or is it quite tight for space? How much are looking for it?
Time to create page: 0.113 seconds
