Squeaking/chirping under acceleration
  • Cameronmike
18 Mar 2017 11:39 #179342 by Cameronmike
Squeaking/chirping under acceleration was created by Cameronmike
Over the past few days a squeaking noise has developed, similar to a squeaky wheelbarrow noise, that only occurs under acceleration. Its most noticeable under heavy acceleration and is not constant but say under normal accelartion from a traffic light will sqeak a few times in 1st and the same through 2nd and 3rd but less noticeable in 4th and 5th. Been driving about for a few days with the windows fully down and the noise appears to be coming from some where under the car and to the rear. Its a 2001 with m13a. Had a quick look under the car but could t see anything obviously wrong, any pointers on what to look for would be great.
Cheers in advance, as always the helps much appreciated.
  • 1066Boy
18 Mar 2017 15:17 - 18 Mar 2017 15:21 #179346 by 1066Boy
Replied by 1066Boy on topic Squeaking/chirping under acceleration
Its very hard to trace a noise on a moving car. It could be the fan belt slipping. :)
Check for rubber dust around the alternator pulley.
Last edit: 18 Mar 2017 15:21 by 1066Boy.
  • gilburton
18 Mar 2017 16:33 #179349 by gilburton
Replied by gilburton on topic Squeaking/chirping under acceleration
Heat shield on rear box has been known to come loose?
  • NicBeeee
18 Mar 2017 18:00 #179356 by NicBeeee
Replied by NicBeeee on topic Re:Squeaking/chirping under acceleration
Try spraying some silicon lube on your rear suspension bushes, one may have become delaminated, squeek would be the slight lifting of the rear under acceleration.
Sent from my F3111 using Tapatalk
18 Mar 2017 18:40 - 18 Mar 2017 18:44 #179357 by facade
Check the crankshaft pulley. Mine made a noise under acceleration in 1st & second for a few weeks before the crank pulley outer ring came off when I was accelerating away from a set of traffic lights.
Funnily enough, I was experimenting with the idea of revving it up a bit in the gears, rather than changing up as soon as I could, because I read a post on here that these teenie weenie engines need to be revved a bit, or it might have lasted a bit longer....
Last edit: 18 Mar 2017 18:44 by facade.
  • Cameronmike
19 Mar 2017 12:52 #179391 by Cameronmike
Replied by Cameronmike on topic Squeaking/chirping under acceleration
Cheers for the replies, will have a look at the stuff mentioned today.
