Whole car is shaking, vibrating
- Szabek
16 Mar 2017 11:56 #179285
by Szabek
Whole car is shaking, vibrating was created by Szabek
Oh no, after a few days of happy ownership some issue came up already.
Last night I wanted to drive home from work. When I started the car, the whole car was shaking, vibrating , while the car was in neutral and stationery. Looked like the gear shifter is going to fall out from the vibration.
I tried to restart a few times, same. I started to drive out from the car park and the engine was reeving , but no power, only managed to do 9 mph. After a few hundred meters something started to smell strong burning. I quickly stopped, jumped of from the clutch (accidentally) and killed the engine. I was scratching my head 5 minutes, looking everywhere, google and decided to call AA. Before I did , I tried to start it again...and voila, everything back to normal.
It did twice since and all the time "the jumping off from the clutch and kill the engine worked".
The whole shaking is very similar than you start to release the clutch and reach the biting point...
Side note: the clutch feels very very stiff since I got the car...
Any idea?
Any idea?
16 Mar 2017 12:13 #179286
Replied by yakuza on topic Whole car is shaking, vibrating
www.bigjimny.com/index.php/forum?view=topic&catid=7&id=61693
Could be mostly same cause as in this thread?
If it had not fixed itself i would say something had come loose like inside clutch or driveshafts..
- Szabek
16 Mar 2017 13:41 #179290
by Szabek
Replied by Szabek on topic Whole car is shaking, vibrating
Ok, i progressed with it further, looks like only 2 pistons running from the 4... I think it is maybe the coil pack
- mickt
16 Mar 2017 20:12 #179299
by mickt
Replied by mickt on topic Whole car is shaking, vibrating
All the pistons will be running as in going up and down, at least for your sake I hope they are! The plugs might not be firing though. Take the plugs out and check if any are wet. If they are then they are not working.
16 Mar 2017 20:42 #179302
by Busta
Replied by Busta on topic Whole car is shaking, vibrating
Definitely sounds like an ignition problem and would most likely be a coil pack. Do you know anyone local with a Jimny you could swap coil packs with to rule it out?
- Szabek
17 Mar 2017 05:23 #179311
by Szabek
Thanks for the advice for everyone.
After my initial 10 minutes panic period, I called AA out (that's why I pay them..), and the guy confirmed it is one of the coil pack. So 40 minutes later I picked up a pair of new coil pack and leads from Euro Car Parts and changed it. Looks like problem sorted, but we will see in the next few days.
Time to create page: 0.104 seconds
