Large hole off road!
- VivaLaMikey
14 Mar 2017 21:13 #179233
by VivaLaMikey
Large hole off road! was created by VivaLaMikey
Heya there all,
Today I was doing some relatively light greenlaning in my 2005 jimny (with no mods other than a snorkel and some strobe lights). I was going around 15 mph and i hit a large hole covered by a puddle. It was totally my own fault. My only issue is, the ABS light has come on and after some hard stops i'm pretty sure the ABS has packed up. On top of that the passenger side hub appears to be grinding, but only when its in 4wd.
Does anyone know of anything i can try at home to fix the 4wd grinding? Do y'all more experienced Jimny owners have any ideas of what the problem is? (other than i broke it :laugh:)
- VivaLaMikey
14 Mar 2017 22:00 #179235
by VivaLaMikey
Replied by VivaLaMikey on topic Large hole off road!
After have a look, i've snapped a cable that leads to the front drivers side wheel, (which i can only presume is the ABS cable) and the drivers side ball joint thats connects the wheel the the axle has quite a bit of oil on it, its not dripping off but its not far off...
I'll let everyone whos interested know what my mechanic says when i speak to him tomorrow...
15 Mar 2017 07:37 #179246
Replied by mlines on topic Large hole off road!
Sounds like stones/mud trapped inbetween the disc etc causing the grinding noise.
It does sound like the ABS sensor cable, perhaps the sensor has been clobbered and is grinding on the ABS ring
If you need a new ABS sensor and harness I have in stock
1. Aftermarket sensor assembly - www.bigjimny.com/store/front-abs-sensor-assembly-p283.html
2. Genuine Suzuki assembly - www.bigjimny.com/store/front-abs-sensor-assembly.html
The following user(s) said Thank You: VivaLaMikey
- VivaLaMikey
15 Mar 2017 14:49 #179257
by VivaLaMikey
Turns out I've managed to bend the front axle and snap my abs sensor cable...
Thanks Martin for your help!
15 Mar 2017 15:36 #179258
by Keithy
Replied by Keithy on topic Large hole off road!
Wow bent front axle!
Gave it a proper crack!!
Was it the puddle frequented by Dawn French?
15 Mar 2017 16:00 #179260
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Large hole off road!
I have a front axle case bare if you need one.
Sounds like you gave it a good whack. Did the wheel and tyre survive?
Grey pick up Jimny
Time to create page: 0.105 seconds
