Overheating after play day..
  • Young Pretender
12 Mar 2017 21:51 #179136 by Young Pretender
Overheating after play day.. was created by Young Pretender
Had a few issues today after 4x4withoutaclub. Despite knowing that I needed to clean my rad and purposefully buying muck off degreaser AND a 7 litre manual pressure hose for the purpose of cleaning it I forgot!
Sorry if this is a bit long winded but here's the detail. I could do with some help..
Took my co-pilot back to Reading train station about 10 miles on slowish roads (no issues) and then hit the A roads out of Reading. Didn't notice the temp climbing so the first thing I noticed was the engine management light, then obviously see the temp at the absolute max . Straight onto the hard shoulder steam pouring out of the bonnet through the breather on the water tank reservoir and the water inside obviously doing a merry dance. Then realised I forgot to clean the rad.
Cleaned rad using the gubbins that I had bought for the job in the first place and it looked ok-ish. Water had settled, topped up reservoir, didn't know to top up rad at this point. Engine temp had dropped to normal temps but engine management light was still on. hmm. Thinking I've fried the head gasket.
Decide to call the AA. When they arrive he thinks I haven't fried the head gasket - says that on this car if they go then oil explodes everywhere (?). Anyway he helps me get the air out of the system. Thermostat sorts itself (I had been getting cold air since overheating) and he says I'm good to go. I have plenty of water on board and he warns me that I may still have issues with air in system so basically do what we have just done if it happens again.
It happened again. Once on M3 and twice on M25. Got quite far before the m3 incident and didn't let it overheat to the point of steam this time. Let it cool. Water in rad is fine (not loosing water), water in reservoir tank a bit high now. I'm thinking the rad isn't clean enough so squirt is with more water - pressure is a bit feeble but it's all I have. Same again twice on M25.
I notice that it's fine if I stay under 50-55mph but If I hit 60mph then temp gradually climbs. I decide to get off motorway so my speeds are lower and I may also find a jet wash to flush the rad better. Found a jet wash but after a couple of minutes I look at the rad and the pressure has annihilated it lol (I know this is getting ridiculous :)). After that I get home without further incident but no motorways.
I'm thinking that my rad was on it's way out and then the mud, overheating and then pressure wash has killed it. SO new rad and obviously coolant.. Sensible? Then see if it's sorted. Or should I take AA mans advice re head gasket with a pinch of salt and investigate further. I'm inclined to suck it and see but could do with a steer please
Sorry for war and peace - I did warn! :laugh:
Cheers
Mark
:laugh:
12 Mar 2017 22:22 #179139 by Busta
Replied by Busta on topic Overheating after play day..
There's no truth in the 'oil explodes everywhere' comment, so ignore the AA man.
One simple check is air bubbling up through the radiator if you run the engine with the cap off. You could also test the coolant with a sniff tester. The kits are about £30 and detect whether gas from the combustion process is present in the coolant.
The following user(s) said Thank You: Young Pretender
  • Young Pretender
12 Mar 2017 22:38 #179142 by Young Pretender
Replied by Young Pretender on topic Overheating after play day..
Thanks Busta, appreciated.
12 Mar 2017 23:15 #179143 by Keithy
Replied by Keithy on topic Overheating after play day..
Time for a new "genuine ebay" radiator! :D
I found the write up quite amusing....AA-RAC etc are OK for taking you home.....never assume they know anything ;-)
  • ZookFastback
13 Mar 2017 02:57 #179149 by ZookFastback
Replied by ZookFastback on topic Overheating after play day..
Did you turn the heater on and off a few times to remove airlock? Does hot air now come out of the heater?
  • Young Pretender
13 Mar 2017 07:38 #179152 by Young Pretender
Yep and yes, now get hot air through the heaters as normal, cheers
Keithy, glad the write up has amused, it's some small consolation that I can at least share an amusing anecdote ;) :laugh:
Time to create page: 0.103 seconds
