Why does my timing belt keep jumping
  • Terrortom
11 Mar 2017 09:03 #179060 by Terrortom
Why does my timing belt keep jumping was created by Terrortom
I put a new belt on went to run it up all tensioned etc but left casing of and everything to make sure it's right before putting back together but each time I run it up the belt jumps half off I've tightened the tensioner up made sure it's tight Etc does the case keep it on or have I done something wrong thanks in advance
11 Mar 2017 11:39 #179062 by Keithy
I'd suspect you've done something very wrong....
  • Terrortom
11 Mar 2017 11:54 #179063 by Terrortom
Replied by Terrortom on topic Why does my timing belt keep jumping
How tho as all I've done is put new tensioner and belt on haven't changed anything else
11 Mar 2017 12:19 #179064 by j999pre
They can walk off the pulley.
Grey pick up Jimny
11 Mar 2017 13:22 #179065 by facade
j999pre wrote: They can walk off the pulley.
Only if something is out of alignment.
The crank pulley outer flange keeps the belt on the crank cog, then the belt just runs straight by itself, and stays in the middle-ish of the cam sprocket.
Are you running it with the outer part of the crank pulley missing?
  • Terrortom
11 Mar 2017 14:36 #179068 by Terrortom
Yes was running it worth out bottom bit
Time to create page: 0.095 seconds
