Headlight Wipers?
- roscoepcoltrane
10 Mar 2017 12:51 #179025
by roscoepcoltrane
Headlight Wipers? was created by roscoepcoltrane
Any idea if it's possible to fit headlight wipers to a Jimny?
I've got a few concerns...
- Where would i mount them? On all the old Volvo's and BMW's it seems there's still a section of flush bumper under the headlight you can mount it flat to, whereas on a Jimny the bumper sits/stick straight out from under the headlights
- Could I get a switch going straight to my dash rather than connecting to my current wiper switch? I thought about connecting them to the same switch as the rear wipers but I'd prefer not to f*ck up my wiring/fuse box - And as good as it sounds connecting them to the front wiper arm/switch, with it's variable speed it seems a lot of stress to put on such a small component.
- Does anybody else think these look cool? Or just me?
10 Mar 2017 15:34 #179032
by Keithy
Replied by Keithy on topic Headlight Wipers?
I've never seen wipers on plastic headlights......could make a fun pattern no?
11 Mar 2017 13:32 #179066
by facade
Replied by facade on topic Headlight Wipers?
With plastic lights you normally just have washers.
I used to have a kit knocking about somewhere, two large nozzles and big pipes for the bumper, a bladder for the water, a high volume pump and a timer relay.
Every time they activated the pump squirted 150ml of water out of each jet in a great fan that blasts the dirt off. As the bladder only held about half a gallon, that gives you around 5 squirts to empty, which is why the kit was knocking around for ages......
The following user(s) said Thank You: roscoepcoltrane
Time to create page: 0.083 seconds
